trammayo
Those of us that run Bachmann Big Haulers on track pick-up will experience the wearing away of the wheel plating (drivers).
I have run mine until the copper underplating shows through. The major downside is that conductivity is severely affected. Showing my trailer layout, several of my BHs are causing problems. As I have seven of these locos, I have been giving the problem some thought.
I thought of battery power, new chassis, etc. In the short to medium term, I am contemplating modifying the tenders into 8 wheel pick up. My initial attempt is somewhat inelegant (or crude) but it does work!
One of my favourite locos is the V&T - so, as this is popular, it was the first to get the treatment.
The tyre wear ....
I dismantled the underside so I could solder a pair of wires to the brass contact strips, and drilled a pair of holes to lead the wires out of the chassis. There are a pair of notches in the cover plate which allowed the wires to see daylight and I drilled another pair of holes in the cab support framework to bring the wires out behind the cab.
With regards to the tender, I chose some 1mm brass rod to make the simple pick-ups. I used the bogie frame screws to locate the pick-ups. The pick-ups make contact near the wheel centres - thus reducing friction. The wire from the tender (and loco) is some 1.5mm stripped out of some flex. I used a lighter gauge wire for solder to the pick-ups (so as not to interfere with the bogies' movement) and both trucks feed to the centrally placed connector block.
Connecting plugs were a problem. The best solution to hand (but not the neatest) was to use some 5amp block plugs. They are clumsy and obtrusive but, since taking these pics I have painted the exposed wires and blocks in black.
Having "belled out" the wiring - it's paramount that the tender pick-ups are the same polarity as the loco's
- I carried out a live test on the garden track. No problems - she ran smoothly over uncleaned track.
I intend to convert at least another four of the BHs - plus I can think of at leasr another three Bachmann (and a couple of Aristo locos) that would be enormously improved by this.
I need to get some more wire and less obtrusive plugs. I thought of making a socket in the tender headstock but I didn't have enough clearance (with the plugs to hand) between the bogie wheels and the underside of the tender floor.
AS for replacing the tender wheels? Once the plating wears on those, they can be swapped with similar wheels from rolling stock. Any new wheels purchased will also allow 'worn' wheels to replace pastic wheelsets.
The tyre wear ....
