AusrailQLD
I feel bad for starting a new thread, but I'm struggling to understand the logic of this one.
ok, so I have a Unitah 21881 that I've converted to DCC.
I've connected the smoke unit to Function output 1, and programmed the Massoth XLS decoder, CV53 to a Value of 5 as recommended.
- The Smoke unit has Black and White wire cables which I believe indicates that it's 5 Volts.
(Also the Loco's original manual saids a 5 Volt unit as a replacement part)
However when running on DCC the smoke unit barley puffs out any smoke.
- The Control unit is a MRC Prodigy Express 2 (With Booster rated at 10amps, 15 volts, for G-scale running.)
On Analog control (LGB own brand), the smoke unit really goes well when the Loco is running at around 19 Volts.
I'm lost as to what I have done.
In theory the output for the smoke should always be 5 Volts am I right?
Was planning to recheck the CVs again, however somehow I accidently burnt my DCC unit when I switched the loco's test track to Program.
