A BRIDGE TO HIGH
  • Thread starter Thread starter ped
  • Start date Start date
ped
N/A
Hi All,
I am building a bridge over my pond,the line will have to cross exsiting track in three places,could any of you good chaps tell me what height clearance i will need for bridges,the tallest loco i have at the moment is a Bachmann Annie wood burner with the big spark arrester chiminey,if that passes under will that surfice or is there anything taller that i might want to run one day,over to you.
Regards Pete.
The model of the k-37 is 8.25 inches tall. This is one of the largest locos in NG and the largest you can buy.
Alec
Thanks for that Alec,I had measured the Bachmann and it is 8inches to top of stack,so not much shorter than the K-37,the clearance i had in mind is 9and half inches so i should be safe.Thanks once again.
Regards Pete
