Hi all,
I?m currently building a gauge 3 tram and now have an Accucraft boiler care of a kind member from this forum, minus various fittings that he needed for his coal fired version.
I have a few questions I need some help with.
Firstly what threads do Accucraft use on their steam fittings? I need to get the connection off the end of the regulator (i.e need the correct dia of steam pipe, the nut fitting and the nipple that solders on the end of the steam pipe) and need the fitting that holds the feed to the drain valve. There is also a plug on the back of the boiler that I would like to wither fit a pressure gauge to again or blank off. Lastly I will also need to get a gas jet and assembly.
Any idea where I can get said parts from? I?m also looking at if I will build some form of smoke box myself or try and pick one up, maybe a roundhouse one.
Thanks,
Simon.
Thanks,
Simon.
