Adding Massoth Sound Card to DCC LGB 29655
Clive
Drama - acting, Woodwork, G Scale, railways
Please Help. I've spent all day trying to fit a Massoth e Motion S sound card to my DCC railcar and trailer - LGB 29655.
I have a white wire and a brown wire on the sound card. The blurb saysthat white is positive.
There is a red wire and a black (+ve and -ve I assume) coming from each of the driving bogies. these are connected to 4 pin points on the DCC card.
I was told that all I had to do was wire the sound card in parallel with any of the two feed wires.
I did this and at first i had sound but no motion. I then reprogrammed the cards to the same address and from then on silence is golden with no motion either.
Is there a video I can watch?
Has anyone done this before?
What am I doing wrong.
Advice please.
Clive
:eek:
Turn the power off! - Just in case..
I lost the photo's I took, but there are a couple of spring-strips under the circuit board.. Make sure these are definitely in the correct place. - I fried a decoder. :rolleyes:
Then a photo is worth a thousand words..
I am pretty sure these spring clips are in the correct place. Bridge on each facing out and sides in the grooves.
You are right. I need a photo please !!!
I meant one from you..
You may have the motor-wires, rather than the track into your card..
Has the switch been inadvertently turned off?
Hopefully this shows all. The sound card (right) is connected to a volume control, loudspeaker and brown white wires to dcc card. i can take photo without motor if it helps......and THANK YOU
Vaguely coming back to me.. I think? :(:rolleyes:
I think I put the speaker in the trail-car. - Where the motor would have been..
Used the S decoder to sort the trailer lights, and had to be slightly creative with the wiring??
Sound card and volume control were in the 'side' of the unit.. - I think I had to cut some of the cover away, to clear the sound card?
I thought I posted something on the Forum? But am unable to find it, sorry.
<edit>
Should the black/red wires be to the same side at each end? - Check with a meter..
