Zerogee
Clencher's Bogleman
Has anyone on here had their RhB Heidi apart? Having just got a non-sound version (20271) with factory MTS, I have sourced a Massoth S to add sound to it, but I've got some questions over the speaker installation. Incidentally I can't find an exploded parts diagram for this loco (or it's factory-sound version, the 20272), on the Champex-Linden database or anywhere else for that matter, anybody got a link to one?
Basically, I've got the loco apart (lifting body off chassis, motor/gearbox and all running gear is still in place) and there appears to be a location for a speaker in the chassis, just forward of the gearbox- however it is covered by a plastic plate (held down by 4 small screws) which also forms part of the boiler support forward of the side tanks. Removing this plate exposes a speaker grill with a round speaker location that looks like it is designed to take one of the ultra-flat speakers with the transparent (mylar?) cone, which I have one of here ready to use - BUT even with this ultra-thin speaker in place you can't then refit the cover plate, which you have to do otherwise (a) you lose the boiler supports and (b) the back of the speaker is actually visible under the boiler when the body is refitted. What am I missing? Does the factory-sound version have a different cover plate that allows the speaker to fit? I could probably cut away enough of the plate to allow the speaker to fit while still retaining the boiler supports, but I'm wary of doing this if there is something else that I should be doing instead....
Anybody have any useful ideas or relevant experience?
Thanks,
Thanks,
