maxi-model
I am in the process of building a number of modern Welsh Highland Railway coaches in 16 mm scale. One will be a service coach. These in real life have a generator set installed and when in a station the continuous drone of their on board generators are quite distinctive. I would like to replicate this built into the coach, #2010.
Ideally I would like a neat self contained unit (but can be separate compatible components) with the sound file already installed. There used to be something called the "Masterblaster" a 50 mm x 60 mm cylindrical unit, that could be supplied with a suitable looped sound file. But it is a tad too large to be ideal but not out of the question. A unit would need to be compact with a means of storing a looped sound file (to run continuously), say an MP3 player of some sort, small speaker, battery pack/holder and an externally mounted on/off switch and an optional recharge socket. There is no requirement to operate by RC, load additional sounds or make the sound variable speed at different voltages. It would be a stand alone sound effect unit with a fixed operating voltage.
Any ideas how I could achieve this and source the component elements to make a simple dedicated functioning unit if not a complete off the shelf unit ? I have both a Windows 10 PC and Android tablet available to the latest software levels to source/download sound files. Warning - I am a total numpty when it comes to anything like this. And yes I have done a bit of research but cannot be sure of making a correct purchase without some advise. Thanking you all in anticipation. Max
This was something that caught my eye MP3 Re-Recordable Sound Chip Module, 4MB USB Transfer. Model making crafts gifts 5060419151767 | eBay and this is the sort of sound file I'm looking for Diesel Generator How I would go about getting it all to work or if they are compatible I would have no idea.
