AMS cablecar
tramcar trev
Mine had an annoying problem in as much as it slipped quite a bit certainly any grade over 1:20 and it slipped. Anyone else had this problem? I solved it by putting 2, 50x20x10mm lead ingots under the seat over the power bogie
Trev,
I run level track on my shuttle, but I do have two cars and each are very different in performance. One ran perfectly out of the box. The other was a pig, requiring tear down and rebuilding, mainly due power pickup issues. I replaced the non-powered axles with Bachmann wheelsets as the stock wheels did not conduct power (even after only a few minutes running from new, the inner faces of the wheels had become hopelessly coated with carbon residue). From memory, I changed out the carbon brush pickups as well.
Mine do not slip, but once rebuilt have been quite reliable. Nice cars but would not recommend them. Check for drag from the trailing truck wheel pickups.
