Sorry Peter I think that answers just part of my query. Think I can work out the chuff sensor bit to be separated, do I just duplicate all the other wires to each sound card?The best solution, if your loco will allow, is to use the option to connect each soundcard to a chuff trigger on each motion. Then the phase of the chuffs will match what you visually see.
Regards
Peter Lucas
MyLocoSound
No.Sorry Peter I think that answers just part of my query. Think I can work out the chuff sensor bit to be separated, do I just duplicate all the other wires to each sound card?
Thanks Phil that is sort of what I was asking, just duplicate those wires for the other card.No.
One card you would use for one set of cylinders, plus other sounds. - Whistle etc.
The second card you would just use for chuff from the second set of cylinders.
Obviously, you need power, motor, and speaker wires on both cards.
