So we have had sundry conversations about the PeppaPig Railbus on the Forum and I eventually gave way and bought one. This conversion is a quite memory bashing one as starting it today 7 years after my good friend Andy Rush of Ruschbahn fame passed away, he would have been pleased to see a few of his Newquid and LGB bits being repurposed in this way. First a couple of pics of what I am intending to make a look alike of. Though whether a Crane will be involved remains to be seen.
Here are the sundry bits laid out. Note that I going to use an IP Budget chassis, though if I can I hope to get Metal Gears to replace the nylon ones, the chassis is already 4 wheel drive having been fitted with Delrin Chain.
I have cut up the Newquid sides and they have been used to make a 2 plank high freight section. These have been glued together after some shortning and Filing of ridges to get neat joints. These are sitting on an off-cut piece of 2mm clear plastic sheet that I happened to have an off-cut that was just over just the right size required of 72 mm wide 78 mm long. The trolley will be powered by 4 aa NiMh Batteries and have a Deltang Rx45 RC receiver. Thius below you see progress up to now.
