beavercreek
A year or two ago I converted my `Local line` shuttle point to point, to be able to run DCC. My `Main Line` had already had that option for a couple of years.
This conversion of the `local` line also brought about a double reverse loop.
The space at either end placed a restriction on the radius of the reverse section and It had to incorporate R1 curves.
It works fine after changing one of the Massoth reverse loop modules as it had become erratic.
So now I have turned my attention to the final bastion of DC power on my layout...the `Quarry` section.
This is a self contained part of the layout, operating as a shuttle point to point as it follows a double spiral path.
There is the option of it remaining as a shuttle but under DCC control. This could be done by Massoth feedback module or by the Tam Valley DCC shuttle unit (with the DCC booster to give the power needed by G scale).....
OR...
Another double reverse loop....
One end is going to be fairly easy with just a rejigging of the present curve at allow the completion of the loop....the problem is that at the other end where the line is elevated some 9 inches along the rear retaining wall and comes to a stop at that level.
So it would have to remain at that level, curve around over the packing plant and lower level track to rejoin itself along the wall.
This is feasible but to make it look good (Trestles would be good but there is not enough room at the front)......, not overpower the packing plant and allow the trains to flow unhindered underneath it...this is the challenge......mmmmmmmmm is it worth it!!!?
Rough ideas.....
OR...
Rough ideas.....
