Eaglecliff
I have been happily using one of these cheap and simple bits of kit, albeit with a 19v 6amp power supply, for some time. I have no intention of upgrading, if only on the grounds of cost and the small size of my layout. However, I have a slight niggle; despite there generally being only a short distance between the handset and the aerial, the signal doesn't always seem to get through and the train carries on its merry way despite me punching the "Emergency stop" button several times, or indeed any other button.
Is there a "best" way of arranging the aerial, i.e. vertical, horizontal, whatever? Is it possible/advisable to replace the wire with the sort of telescopic type generally fitted to radios, or something else? Or is it the handset - same questions? I notice that some more advanced/bigger systems usually have longer aerials on the handset.
