Thank you. Since the wear on the drive shafts from the little ball bearing is minimal, I am going to assume that the loco has not run for many hours. It is the age of the grease that was causing me concern. If I could have found a way to inspect the grease and renew it easily, I would have done so. However, unsoldering the joints on the motor lugs has proved too difficult at present, so I cannot really proceed with dismantling. Before I drill holes in the gearboxes , I shall try another test run and see what the noise levels are and motor amps look like.
I am very grateful for your help and advice. For your information, I bought the loco secondhand some years ago. It quickly became apparent that one bogie was noisy, so I bought a brand-new bogie ( from Bachmann, I think??) and swapped it over. The original noisy bogie was then partially dismantled, to see if I could find the source of the noise. In doing so, I lost a spring and tiny ball bearing from one gearbox. I then snapped one of the thin metal "legs" which bring current up from the spring clip on the outside of the gearbox to the top of the bogie. By this time, I realised that these mechanisms were not designed to be maintained. I have extracted one gearbox from within the bogie, dismantled it and found very little if any grease and no wear on the axles from the little balls. I have drilled holes in it to see how best to proceed.
Regards,
Malcolm
