Aster Jumbo with custom coachs
I enjoyed the video and watched it a couple of times! Thanks!
Questions:
Did you build the coaches yourself or ?
I like your track setup with the interlocking blocks on the outside. That's a nice way to setup the railway in an open area. What is in the middle between the blocks that supports the track, normal concrete blocks?
Thanks.
Thanks for the kind words. The coachs are scratch built. They still need some details added. Between the blocks is drainage gravel and then paving block pulverized bedding under the track. It does need re ballasting.
smoking!!!
absolutely the best most throaty chuff ive ever heard on a model if it's size, bar none
and, none of that reverse loop wiring nonsense either LOL
