Flying15
This is another lock down project
It involves building something close to a LSWR G16 tank engine as built to Marshall freight trains at Felthams hump yard
The chassis is basically an Annie chassis with the cylinders inclined and re shaped to represent a piston valve block, some metal work on the support bracket removed etc
New coupling rods to represent the eight coupled wheel base were made from 4x10mm steel
The trailing (new) wheel set isn’t actually connected and free floats, an idea I pinched from the old Lima O gauge 4F model
The wheel set is from a Stirling tender and is the same diameter as the Annie drivers
The bogie wheels were swapped for a set of large wagon wheels from GRS
The body is built mainly from plasticard and the boiler is from a length of rainwater pipe
The chimney was cut down from a Bachmann stove pipe one in my scrap box,
the dome is a GRS casting I think intended for a narrow gauge saddle tank.
The loco was painted in an earlier LSWR livery than actually carried by this type as I like it!
The transfers were courtesy of Fox transfers
I think there’s a few details I need to add including the reversing mechanism and perhaps drain pipes from the cylinder cocks?
