Bachmann Gandy Dancer wheelbase ?
Corto
I'm planning to buy a Bachmann G scale Gandy Dancer but I'didn't find the wheelbase.
Could you help me ?
Thank you all for your answers.
If you mean the Gauge, then they are the same as any other "G" gauge piece of rolling stock. They run on 45 mm track. If you need the measurement or center to center dimension from the front wheel to the back wheel, then I'll have to measure it and get back to you.
Thanks. Could you tell me this dimension?
Could you also tell me the wheel diameter ? Thanks by advance.
45mm wheelbase and 27mm wheel diameter if that helps
:o Beware, it is a very light duty mechanism, it would be no good for hauling anything other than the trailer it comes with.
Thanks. Very good advice.
