Hi Folks
I recently bought a second hand Heisler, in very good little used condition
apart from a few cosmetic faults (now cleaned off) and the top of the original
tender missing, it really is very neat and clean.
BUT - at very slow speeds it seems to 'Pulse' for want of a better description ???
Can any body shed any light on what might be the cause.
I have gone through the maintenance regime and it runs as sweet as can be
pulling very smoothly once past the initial slow start/running problem.
This 'Pulse' effect is so pronounced that any other loco on the track at the same
time pulses as well, as do any lights (track powered), they go on/of at a steady
rate, also the lights on the TE and a slight buzzing can be heard from the transformer,
all returning to normal once a steady speed has been reached.
Motive power is analogue from a 5amp Gaugemaster via an Aristo TE, i have tried
it on 2 diff transformers, 3 dif TE's and a 1amp LGB controller all with the same results.
On stripping it down, all appears normal mechanically with no signs of stiffness or binding.
On removing the tender body there appears to be an extra circuit board ??, i have never seen before, could this be the cause. ?? Pic's below any idea what it might be??
Any idea's welcome - as it is quite frustrating having it sitting in a box not earning it's keep
especially every time SWMBO looks at it with that all knowing look.
I have not used it above initial tests, incase i may be causing damage to the Heisler or other electronic's
Pic's with the tender body removed
Extra board appears glued to the balast weight at rear of the tender
From above
From above
