Bachmann Little Hauler(with tender) & 2-4-2 Columbia or 2-6-0 Indy dimensions
norman
Hi Guys:
Would someone know the following dimensions?
1) Little Hauler loco with short tender:
smoke box diameter
smoke box length
boiler length
cab side body length
2) ?Hawaiian 2-4-2 Columbia or 2-6-0 Industrial Mogul:
smoke box diameter
smoke box length
boiler length
Thank you,
Norman
Indy:
Smoke box dia 43mm (external), length to first ring 41mm, ring 2.5mm (yes I know it looks like the smokebox is longer than its diameter but I have just measured it twice with a micrometer...)
The boiler intrudes into the cab so without dismantling, the nearest I can get to boiler length is 146mm (from rear of first ring to backhead)
Presume by "cab side body length" you mean the horizontal length of the vertical sides of the cab; if so that is 84 mm (excluding the grab irons)
Steve
Hi don't know if these measurements are of any use from the Lil tank loco (they share the same cab and the boiler looks to be the same length);-
Overall width over cab window cills =
106mm (the cylinders stick out a little more - around 1.0mm each side.
Cab length (sides) 50mm
Height (from rail head to chimney top) =
144mm
Wheel centres = approx 67mm (but nearer 68mm)
Wheel dia. = 34mm
Boiler dia 48mm but, as tanks are part of the same moulding, the o'all width is 100mm (which would be over the footboards in your case).
Boiler length (not including number plate on smokebox door) 143mm
Length (not including coupling/s) from rear of cab roof to front of pilot board =
250mm
