JimmyB
As some may see I have an issue with my Railtruck, going up an incline a 'ratcheting' noise could be heard which I thought I had fixed. Complete strip of the gearbox and the plate holding the bearing was loose (blue arrow), having tighten the screws, and run it in its stripped dow condition it seemed to be solved. Reassembled, second circuit and the problem is back, stripped and closer inspection found the bevel gear (red arrow) is split. Bachmann part 00Q03 is available from the US, but does anybody know of a UK supplier.
