Bachmann Tram - changing lights to LED
GriffsGrandad
Slowly plodding my way through all the interesting posts on here, but so far I've not found what I need so I'm hoping for a little help please...
I'm doing a very crude conversion to battery power with control over wi-fi to an ESP32 in the tram. Everything is going in a trailer wagon for now.
How would I get to the directional bulbs in order to change them to LEDs, so that they can be switched on & off at will via a low power signal from the ESP32?
Is it feasible/easy to convert the interior lights too or are they too fiddly?
Many thanks.
Les
The headlights on the Bachmann trams are almost impossible to change without destroying the tram. I'm sure you noticed the raceway under the tram for the wiring to those lights. How those Chinese workers get everything in there is beyond my comprehension. Not only are the very fine wires tucked into the zig-zag raceway, but once you are able to pry the thin plastic cover off the bottom of that raceway, the wires are still glued in place.
All in all I still love the Bachmann trams for their fine and accurate detailing.
One more thing to consider, if you haven't already, swap out the Bachmann motor block for a USA Trains NW2 motor block. It's a fairly simple swap and the spacing of the axles is almost identical to the Bachmann axle spacing.
Thanks, Dan.
I suppose I could just run new wires from the ESP32 chip directly to the light housings, but I can't see an easy way to get into the front & rear housings. Any suggestions, please?
I've seen quite a few comments about the USATrains block, but don't know if they are easily available in the UK. So far, I've not had any motor problems with either of the trams I have - fingers crossed.
Thanks, Dan.
Garden Railway Specialists sell them.
The link below is to my blog, which details amongst other things changing the lights to LED, 3mm LEDs will fit nicely in the original fitting:
