Bachmann Tram Conversions
DafyddElvy
With all the ideas etc floating around in my skull, I thought I would share a couple here, I openly and unashamedly admit not all the ideas are mine, some have come from other peoples projects which I either think are good ideas or variations there of. It would be interesting to see what others have done to convert their Bachman trams.
Douglas Head Marine Drive Tramway is the first post, rather unique this was the Isle of Man's only standard gauge track system on the island, also unique the stairs at both ends led up to the same side of the upper deck, for a third point of uniqueness, they had the trolley poles mounted to one side of the tram.
An ideal conversion project for a Bachman tram, not to a scale model but as a representation of the prototype.
Well you could convert the gauge to G3 (63.5) to make it right.
Another possibility is the Denver South Platte River tram.
Two Bachmann open tram bodies and a wee front/rear platform extension, and hey viola another representation conversion, and this time a bogie vehicle.
One that someone else has already done, a Cairo tram and the person doing the conversion has even produced a stage by stage photographic record of how it was done.
Another one someone here has already done, Bachmann tram conversion to a Duncan and Fraser single truck tram of the type which ran on all four Victorian tram networks.
Possibly rather than calling this one a conversion I would think of this model as an adaptation of parts from a Bachmann tram, a very nice model indeed.
It did end up being a bit more involved than originally planned. A fun variation of this type of tram could be the original California combination form too.
That's a nice looking tram, have to say it looks a little end heavy for a 4 wheel tram.
The end throw on corners must be quite something.
A nice model using parts from an open and enclosed tram to build this one, with some parts left over.
Before flying off to see trams in Porto, sorry take my wife on a birthday trip to Porto, I started work on converting a cross bench tram to represent a cross bench tram based on one from Sintra.
After removing the centre seat and turn the other two seat units around it has increased the wheel base slightly which I hadn't expected.
While at the Porto tram museum I spotted a replica cross bench tram which i think it would be rude not to try and model having seen it in the flesh ;-)
Hi David,
I‘ve just spotted this post…still finding my way around. Trams on Guernsey had the trolley pole on the sides of the body as well…it may be an insular thing…
Cheers
Martin
This is my LGB Hamburg tram conversion if it counts ? My first ever bash and still a project started but not finished
Im a printer by trade, large scale promotional fabrics to be exact so have a a printer that can print and cut vinyls too. It’s sealed with a gloss varnish.
Wow, they must be thin as I can’t see where the edges are. I presume they are self adhesive? I make my own water slide transfers, but although the print quality is great, getting the right amount of sealant on the transfer paper is very hit and miss, plus the fact I have to cut a circle out which is not very easy. If I use a circular cutter, it leaves a small but very noticeable mark in the centre of the transfer.
Hi David,
Cheers
Martin
A number of early electric tramways used side running trolleys. This had a number of advantages at the time; first it allowed the trolley stand to run down the outside of the car and be attached to the steel underframe of the car, this relieved the weight from the roof of the car and forestalled 'roof sag' and 'banana-ing' of the car body.
The side running trolley enabled the overhead wire to be moved to the near side of the car and holding it up by short bracket arms from the traction columns. The side running trolley was used as part of the 'clear sky system' with the wires close to the kerbs (and trees of any where planted) and the centre of the road still clear to the sky. The American system with span wires across the whole width of the carriageway had been heavily criticised on aesthetic grounds when it was installed on the Roundhay line in Leeds.
The South Staffordshire Tramway used side running wire, but they combined it with swivel-head trolleys so that the trolley head could be further from the tram track centre line. This provided a much neater rig, but it did mean that trolley switches had to be put into the wire at turnouts etc.
A number of tramways that ran alongside sea walls etc., such as the Guernsey line and Douglas Head line used side running trolleys and single sided cars to simplify maintenance.
Hope this helps
