Battery power for carriage lights
HobbitFertang
Hi folks,
has anyone tried powering the internal LED lights of LGB RhB carriages using battery power in place of track power? I thought maybe 2 x 9V (PP3) batteries in series wired to the axle take-offs??
Thanks PhilP. Does the track not usually supply 18V?
It depends...
Are you analogue or DCC?
If analogue, you get 0V to whatever.
If DCC, you get whatever your CS is set to.
The lights should work on either system.
But if you have a decoder in the lighting system, it will require around 5-6V to wake-up the electronics.
