The Birmingham Mail is reporting that Centro are planning battery powered trams for
central Birmingham to avoid trolley poles etc. It suggests that the existing orders for trams can be amended.
I guess it is cheaper to maintain batteries in the depot than a distributed set of overhead wires, regardless of the perceived eyesore.
Apparently, a lot of these were running only on their diesel engines....
Why use overhead wires. There used to be a system of underground wiring for trams.
Think we need to remember that one of the major objections toTram Systems has been the effect of Overhead Wiring not only in the Street but the effect of them on the views of very old buildings. It is also somewhat problematical to string Overhead on old buildings that will be in the route of the next bit of Brums Trams.London, no less. Even then, they switched over to trolley wire once clear of the city, NIMBYs who didn't want overhead spoiling their view of the smog.
Quite likely as they were always on as I believe. However the London Skate System was another option but suffered a little due to crud getting into the slots. But it did last till the end of Trams and a bit of Track can be seen at the north end of the Holborn Subway Exit just north of Holborn Kingsway Tube. Best viewed from the top of a Borismaster running between Euston and Waterloo.Modern technology might make 'stud pickup' work..??
Didn't older technologies kill horses, and the odd 'street-urchin'??
Wireless trams common abroad. Bordeaux and other French systems use Alstom's system: on street power rails flush with the street surface and live only when a tram is over them.Modern technology might make 'stud pickup' work..??
Tell you one thing, batteries wear out a damned sight faster than overhead wiring.
