Battery USAT SD70-MAC Railpro
DGE-Railroad
The Orchard Line
A bit of a change of pace from the steam conversions I've been tackling lately. Time for some diesel!
Here's my USAT SD70-MAC which had been my first Railpro conversion.
I have to say, plumbing in only one module and then configuring it all in the handset makes for a quick and easy installation
I decided to put a battery in the fuel tank for the time being, as I'll be sharing it between locos inotially, to get an idea of runtime.
As the install was straightforward, I decided to have a bit of fun and animate the top fans.
I did this by creating a chamber beneath them, mounting a 12v blower fan on that and running it through a little voltage regulator.
Here are the conversion pics. There are a few things to finish off - the grab handles need to go back on the front and I need to recomfigure the ditch lights, so want running with those or the cab/number lights.
And here's the test run
SD70-Mac maiden run
Can I ask where you bought the voltage regulator and fan? and you needed it because you were running a 18 v battery right? If I were running a 14v battery would I need it, or did you use it to cut the speed and blow of the fan down so that the models fans would spin realistically? Nice idea, I am new to all this but I like the idea.
