Although it states G Scale on the box I guess that at 1:32 it is nearer gauge one.
This latest version ran well more or less immediately out of the box although the gas burner jet became blocked after a couple of runs. I suspect that it had picked up some 'foreign body' out of the tank which now appears to be clear.
I had heard of some problems on the earlier editions but the Chinese manufacturer is obviously a quick learner as no such problems have appeared on this model.
Anyone running this engine can expect admiring comments as the detail and ambience of the prototype has been well captured.
For 1600 (give or take) you are getting an engine which includes an easy to view water sight glass, pressure gauge. Goodall water feed. forward/reverse Stevenson valve gear, drain cocks, displacement oil feed and fitted R/C including transmitter.
It also comes with re-chargeable batteries for the servo with charging connection which can be seen on the video in the bunker (normally fitted with a coal cover.)
Please see it running on my video http://youtu.be/yL39hM4fUxU [...12/8258e230a6ea48cb9f315d66f0710e27.jpg[/IMG]
