![United-States Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-States.png)
Thanks yeah that is big.Hope you have a lot of room will be big, oh and plenty of cash as it will cost mega bucks to be designed and printed commercially. 1595 feet long 127 feet above water, 1:29 scale that is roughly 55 feet long by 4.3 feet high.
I actually made it to be bigger than that. The length, including approaches, is 6,016 feet, which at 13.5mm to the foot is 81.216 metres or 266.48 feet. The central span, alone, is1,595.5 feet, which comes out at 21.539 meters or 70.67 feet. Not sure there is enough 3D filament in the world to build that.Thanks yeah that is big.
Would any printing be strong enough to cope?I actually made it to be bigger than that. The length, including approaches, is 6,016 feet, which at 13.5mm to the foot is 81.216 metres or 266.48 feet. The central span, alone, is1,595.5 feet, which comes out at 21.539 meters or 70.67 feet. Not sure there is enough 3D filament in the world to build that.
I went for just the published bridge size, indeed if you count everything else one would be into serious planning issues in UK, USA likely to have similar planning requirements.z gauge more realistic to get it done, even then be quite big thinking Z model of Forth Bridge.I actually made it to be bigger than that. The length, including approaches, is 6,016 feet, which at 13.5mm to the foot is 81.216 metres or 266.48 feet. The central span, alone, is1,595.5 feet, which comes out at 21.539 meters or 70.67 feet. Not sure there is enough 3D filament in the world to build that.
