Car roadways
Kev Green
OK I've tried a method of creating roads for my buildings which hasn't worked very well. What do people use for outdoor roadways?
How is it secured down. On what substrate?
I use fine roofing felt for platform surfaces (PVC foamboard) and coarse for my raised wood baseboard, and to avoid puncturing it with tacks, stick it down with Black Jack bitumen paint, applied by brush - can be messy but does work. You have a couple of minutes only to apply the felt before it starts to go off.
Thank you for your kind words David,
My railway is raised of the ground ,built on tantalise timber planks .the shed roofing felt is rolled out 1st, over the entire area. To have roads, the grass, or buildings and pavement are added last..if it needs to be pined down,it's done were it won't show,ie under the buildings ect..
It's has performed quite well, you can walk on it, it's easy to clean up..20230525_215612.jpg
Concrete works for me, a paint over with exterior black paint and some silica sand does the job. The surplus sand can be wiped off then painted black again.
I have used wet/dry emery sanding cloth bonded to some type or flat weather proof substrate for outdoor use. The emery cloth can withstand weather extremes as it is designed to be used wet.
