artfull dodger
		I am looking into changing my LGB 2018d mogul to be able to run on batteries and using Keithco Locolinc RC system that I already have on hand.  My plans were to use two 6 cell 5000 mah NImH batteries in series. They are 7.2vt each, so in series I bump the voltage up to 14.4.  I plan to feed the mogul thru the power port wiring thats exhisting in the tender.  This will also run the factory 5vt lighting and smoke unit(which is disconnected as I never use it). My fears is these batteries wont have a decent run time.  One of my requirements for battery conversion is everything is onboard in the tender.  One of these batteries will run an LGB Stainz for over 7 hours non stop.  So I am hoping they, together, will give atleast 3-6 hours run time in the mogul.  I will have to get a different charger that can charge them together, otherwise I would have to disassemble the tender every time I needed to charge.  I have my wiring set up so that thru a DPDT toggle switch, I have a center off position, toward the rear of the tender to tie the batteries to the charging jack, and toward the front of the tender to run the locomotive.   Any thoughts or suggestions?   Mike
