Zerogee
Clencher's Bogleman
I've just received the final coach I need to complete the rake for my Piko BR64, a 37602 baggage combine to match the three regular coaches I picked up a couple of weeks ago. The batch of three came already re-fitted with Piko metal wheels, but the baggage car is still on plastic wheels, which I need to swap for the 3-axle metal set I sourced a few days ago all ready for it. These are the "rebuilt" DB green coaches with the three axles each and the clever articulation underneath to allow the 6 wheel chassis to negotiate tight curves.
Not having owned any Piko rolling stock before, I thought I'd just ask on here before I manage to break something.....
Unlike LGB wheelsets where you flex the axle boxes gently outwards to remove the wheels, with the Piko ones it LOOKS like the axles are a "snap-fit" down into their bearings - however I've just been applying a moderate amount of BFI (Brute Force and Ignorance) to the plastic wheels and they really don't want to budge. Should I simply up the amount of BFI until they pop out, or am I missing something that should be blindingly obvious?
What I'm afraid of, obviously, is putting the BFI off the scale and snapping off a vital and expensive-to-replace bit of plastic!
Anyone else own some of these, or other similar Piko stock, and can offer advice?
Thanks in advance,
Thanks in advance,
