newboydave
G scale trains - no surprise there then!</br></br>
I understand that 'Cuffed2Bits' is no longer trading as Mike Derby has retired, but does anyone know if the business has been handed over to another person or company?.
Not as such..I understand that 'Cuffed2Bits' is no longer trading as Mike Derby has retired, but does anyone know if the business has been handed over to another person or company?.
Hi PhilP. Maybe you can help. Mike did a re-install of the RC system to my Accucraft 'Lawley' (2005 model) in 2022, and it has worked fine until recently when the whistle, and direction controls were working OK, but the throttle just did not move. Now none of these controls function. I have ordered a new charger in case the fault is there, but once the loco battery pack is charged and if the result is still the same, would you be interested in having a look at it, and if so where are you based?Not as such..
But..... If you are talking about the RC equipment, then I might be able to help?
It hasn't just come unbound from the transmitter, by any chance?Hi PhilP. Maybe you can help. Mike did a re-install of the RC system to my Accucraft 'Lawley' (2005 model) in 2022, and it has worked fine until recently when the whistle, and direction controls were working OK, but the throttle just did not move. Now none of these controls function. I have ordered a new charger in case the fault is there, but once the loco battery pack is charged and if the result is still the same, would you be interested in having a look at it, and if so where are you based?
Hi Phil. Tried that. Disconnected the linkage. The regulator 'arm' or 'handle' is very free in movement. I was able to move the linkage up and down relatively easy, but when I reconnected it again, switched on the Controller - the linkage returned to the closed position, and when I moved the Controller to 'Open, there was no movement in the linkage and the 'buzzing' started again!!!The servo is not powerful enough to move the regulator, which is stiff/stuck..
Disconnect the linkage, and the manually 'waggle' the regulator back and forth to free it up.
CAUTION!
Try not to lengthen/shorten the linkage, as it can be quite critical.
