pghewett
Having dug my Countess out of hibernation at the first sign of fine weather, I find that the battery apparently isn't charging. The loco is equipped with the standard ex-works Futuba charger, battery and r/c module. I have, however, no means of determining whether it is (a) the charger (b) the battery (c) the on/off switch, or (d) the r/c module itself which is failing here. (It isn't the r/c transmitter, which is functioning normally, nor the cabling in the loco which seems to be all tight and in place, and the mechanical parts all function perfectly). The charger gets warm when plugged in but fails to display a red light, which is what led me to suspect the charger is the problem.
Does anyone have a - simple - means of determining which link in the chain is at fault, short of dismantling the entire electrical circuitry?
Graham H
Graham H
