ge_rik
I would like to replace my LGB hook & loop couplings with something more realistic BUT ....... although hooks and loops are unrealistic they are cheap, simple and they work on the undulations of my track (provided all stock has a hook at each end).
As my line is a fictional UK based NG railway, I'd like to change to some sort of centre buffer chopper system. I'm not that keen on the hook and chain approach adopted by most 32mm modellers as I do a lot of shunting and stock movement. The Accucraft couplings look good but at £4.60 a pair they are prohibitively expensive for the amount of stock I have - and they don't alllow close-coupling. I've experimented with Binnie Carmarthen couplings but they can't cope with my undulating track.
I'm considering making my own chopper couplings and have started experimenting but scratchbuilding in brass is fiddly and time-consuming. I just wondered if anyone has already trodden this (or a similar) path and can suggest a short-cut.
Has anyone had experience of making brass etches for example?
Rik
Rik
