Creating Faux Granite
tramcar trev
Creating faux granite or stone was my aim in this exercise. My WWI Memorial plinth fell to bits and after a bit of research I decided to go down the road of making my own fake stone. To get real granite cut to size was expensive and the texture would have been over scale. Sand has just the right size for the different colour flecks in the real stuff.
Ok from the benefit of my experience this is how I did the job;
    Washed my sands carefully to remove any salts that inhibits the curing of the resin. Modellers tip, keep some strong plastic bags with you at all times so that you can scrounge sand of different colours as you travel around.
    Mix some sands of various colours to get the colour you want remembering that once the sand is mixed with resin the colour will intensify. To get an idea of the finished colour wet some of the sand mix.
    Measure out the quantity of sand needed to fill the mould either using maths or more practically by filling the mould with sand then tipping it into a measuring jug. Its important to know how much sand will fill the mould.
    Then prepare the resin, I used polyester resin because it states clearly on the package that it is both weatherproof and UV resistant. You will need around 1/3 mixed resin to whatever the volume of the sand is; in my case it was 150 ml sand so 50mL of resin makes the mix pourable. So now you ask if the mould takes 150ml of sand and you add 50ml of resin you must have 50ml left over, but I didn’t have that so I’m assuming that there is lots of air between the grains of sand that the resin fills. Mix the resin with its hardener slowly, lets not agitate it too much you DO NOT want too much air in it.
    Slowly fold the sand into the resin, once again trying to avoid the inclusion of air... DO NOT do it the other way around and pour the resin onto the sand. If you find the mix too stiff add more resin/hardener mix. If you have too much resin the sand will sink to the bottom leaving a band of clear resin at the top.
    Pour the mix into your prepared mould slowly and try and tap or vibrate the mould to get any excess air to the surface and allow to cure.
    Demould and allow to cure off the excess MEKP, best done outside in the sun and rain for as long as possible (7days) before sticking anything to the job....
I haven`t described making the mould, we have done that before but I should give a warning re the Polyester Resin. The hardener (catalyst), Methyl Ethyl Keytone Peroxide is really dangerous stuff so its best to work using disposable gloves and some form of eye protection are the basic necessities for safety. Of course you could use Epoxy Resin.............
I shall be able to make “sheets” of roof tiles and bricks using this technique with either terracotta coloured sand from Peterborough and deep red sand from Alice Springs (Bricks can be any earthy colour) and pressing chopped strand fibreglass cloth into the back of it.
The dark red granite I made looks quite convincing and bears a striking resemblance to the Granite used to create the Devils Marbles and Murphy’s Haystacks....
That looks great and has a 'scale' polished look to it. Like it!
i really like that , it just looks so right.. thanks ???
Looks like granite to my eyes.
Excellent - perhaps this should be copied to the "Knowledge Base" ie in the "Manuals / Instructions" section for future reference?
Depends where you come from, some places only have grey granites, we are lucky here we have just about any colour even green (must have nickel in it?).....
Just stumbled across some crushed grey granite "dust".... I'll give it a wash and dry and see what it looks like when wet with resin... I have more to do yet, I am going to make up a mould so that I can make granite blocks to build buildings from. I figure it wont take much to make up some full and half blocks as well as some shaped to make arched windows with a keystone etc. Someone here made a mould to make up resin "tiles" that looked quite realistic....
Well Trev, if I wanted granite dust, I'd go up the road, nick a bit, and take Mr Lumpy to it - like I did my gold-ore bearing rock! :) :) And doromites from up the hill for another model... I call that authentic.
I've messed around with the resin that "jewellers" use to make trinkets, to cast a particular sign that used to be in Gosnells, but found getting the 50/50 mix of chemicals so difficult - either too bendy, or too rigid it snapped.
I know you were selling some spare stuff, but I've found that liquid latex very easy to use to make moulds..stuff they make plaster-cast gnome moulds, although no gnomes were hurt in my experiments, because I didn't want Elf'n'.S....GROAN, I can't go on...
Merry Xmas
Do you use a mask? I have always used a mask when Im working with fibreglass. I made some fibreglass scenery fly wire over wooden forms and that worked well. its strong I can stand on it. Im going to try your method now brush the top with resin and then sift different coloured dirt over it before I start adding the greenery. Great BLOG BTW.
