Mods: Please move this post if there's a better section for it.
I am looking for help on planning electrical track isolation sections - background as follows:
I have been using the Piko Navigator DCC system for some years now and generally find it excellent. Until recently, any layout was constructed each time the grandchilren wanted something to do on a rainy day and the ability to be able to simply connect two wires whatever the track configuration at the time was a real benefit. Now, with the grandchildren getting older and becoming more computer-savvy, it's time for a permanent layout in the loft.
All track planning is complete as is a 'proof of concept' layout so it is now time to start laying permanent track. The strategy is to future-proof the track section design to allow simple DCC 2-wire operation to start with, adding mimic panel control (Megapoints System 2) and then to full computer control (JMRI or similar).
But I'm stuck already! My initial - and fundamental - questions are as follows:
1. Is it OK just to electrically isolate one rail (assuming I'm only using one DCC supply source)? Techincally, I can't see why not.
2. I cannot find any discussion / explanation why points and crossings should or should not be included as part of a block. Any advice gratefully received.
3. The layout is all single track continuous loops with bi-directional running (and will be signalled as such) so does this mean (for instance) that I will need additional isolated sections inside blocks and / or multiple occupancy detectors per block?
4. If I decided to use Automatic Braking Control (diode system) would this reduce the number of isolation sections within a block and has any one used it successfully with bi-directional running?
Sorry for such simple questions but I don't want to lay track until I have a better understanding. Is there a go-to explanation out there somewhere? I've been trawling the internet / you tube/ etc for weeks and there is a lot of authoritive but conflicting information out there. Even the absolutely excellent Megapoints vidoes haven't put my mind at rest.
Any help and advice most welcome.
