I have an expensive to me, Piko Loco which has a built in SoundTraxx for sound. I am running just in DC mode and use track magnets to trigger bell and whistle. Chuff sound is great to me. Running on about 75 feet of LGB track. I have a DC 10amp power supply.
Believe it or not I run the loco with New Bright cars which have great Christmas decorations, animation movement and lights.
The NewBright tender is wired to the car behind it and so on to the next car. There is some type of DCC controller in the NewBright Tender but I am NOT using the NewBright power supply nor controller. So simple track power is getting me 90% of the lights and animation movement. I am not getting the Light Posts on each car to turn on with simple track power (even though simple track power turns on the other car lighting effects).
Here comes the question. In testing, if I use the NewBright power source and the NewBright controller, I can get the car Light Posts to turn on by pressing the New Bright "Forward button". This "Forward button" on the NewBright controller also provides forward power to the track for any loco. Can I connect BOTH my 10 amp power supply and the NewBright Power supply to the same track setup at the same time? Will two different power supplies on same track cause problems? Only reason for me doing this would be to use my 10amp power supply to run the train and use the toy NewBright power supply to get the car Light posts to work. I don't want to risk my expensive Piko loco/tender electronics from getting burnt out by two power supplies on same track.
Thanks for any guidance
