Diesel fueling tank
Bill Barnwell
Recently purchased a USA Alco S4 for my layout. I picked it because it fit in the era that I wish to run (if possible) early 40's + and the S4 was not built then but the S2 was and the only difference between the 2 from what I understand is the type of trucks. Figured most would not know the difference at it is a pretty recognizable engine with cab in the rear like a steam engine. Now I've built a coaling tower, water tank and a sanding house for my steam engines, but didn't have any fuel for my diesel, So being as I only have 1 diesel I didn't figure I needed too big a one. Started with a 1 1/4" pvc reducing slip "T" the branch part is 1/2" pvc, then cut the ends off 2 1 1/4" caps with rounded ends and glued the together. did a little sanding to remove signs of a joint. Also cut the end off a 1/2" cap for the top. Added some styrene strip to simulate hinges, and a train car break wheel for detail. The end of the caps had the brand name of LASCO so I removed the L and now says ASCO which is the name of a large industrial company that is in solenoids and liquid movement. If you remember the European tank car that I turned into lumber company water tank, well I had the upper structure left over with the ladders and for the base I had the tops that had been cut off of aristo craft transmission towers. wound up fitting pretty good. Labeled it with silhouette machine. Whole project cost about $ 5.00 and a couple of afternoons.diesel fuel tank in progress.JPGdeisel fuel tank top.JPGdiesel fuel tank profile.JPGdiesel fuel tank.JPG
Great job on the build
The tank looks too clean compared to your great looking walkways ..
1 says good and dirty you say too clean, what to do, what to do. Actually the tank is suppose to be aluminum (less corrosion) and the tower and cat walk is steel, hence the rust
