notofthiscenturyTim
I have an LGB Fortuna Flyer which I would like to digitise. See attached product photo. It's basically a flat bed wagon with a motor and propellor on top. It's from the 90s and its manual predates LGB's decoder recommendations.
The slightly more modern Mars Flyer, which has an identical motor and propellor setup, was designed to take an LGB 55020 1.5a decoder.
The main challenge with the Fortuna is that space is incredibly tight inside the housing which contains the motor. An alternative location is under the frame above the axles, but it would be exposed to the elements.
The most promising decoder that I have found is the Digitrax DH465 at 52x15x3mm which has been successfully used to digitise the Mars Flyer, though that has lot more space in the housing. So my questions are:
1. Has anyone successfully digitised the Fortuna Flyer?
2. Are there any really other compact decoders which can take 22v 1.5a or higher that I should be considering?
3. If I end up having to mount the decoder under the frame, what methods have people used which work well for weatherproofing decoders without compromising cooling?
Thanks! Tim
Thanks! Tim
