I couod probably fit one on my Jack easily as I have a bkeed off, not so sure about the Stanley but easier to hide stuff. Mustvthink about this some more.
Thanks for the update on your install. Problem for me with Jack is that I have installed the Batteries in the Cab and do NOT want a Tender. Not sure but are you saying that the Whistle needs a separate Servo? On mine I have used a Spoerer setup and have spare Switches on the Sender and spare points on the reciever.
I am using his TX23 and one of his Receivers. Other than that it is a normal RC Setup using the existing Servos as supplied onnthe Roundhouse Locomotives. Link to the site. Real benefit is that you can drive the Loco one handed. Essential for real Operating when you have Simplifier, Wagon Cards and Uncoupling Tool to manipulate. The Aircraft Type RC Setups are just hopeless for such a system. Mt TX23 has 2 Spare Outputs so one will probably drive the Whistle just fine. If I get a Whustle I will possibly experiment with the Push Button to start with. He has not yet got his Web Site upgraded to show the TX23. There is an even newer one out with much better range.I am not familiar with a Spoerer set up?
http://www.peterspoerermodelengineers.com/90275/info.php?p=2
