Hello all,
About 15 years ago, I switched from an HO Gauge layout to a G Scale Layout. I built it indoors on the second floor of my barn. It has approximately 150 feet of track around the wall of a 20 X 24 room.
I needed a larger power supply than the two vintage 1 amp Troller units that I had been using since 1981 when I started the first HO layout. I wanted a dual pack and I decided that 5 amps would give ample capacity for even the longest trains.
Some research on the internet found a nice schematic. It’s shown here with a list of the components and their values:
http://www.aaroncake.net/circuits/supply.asp
I also decided to use two LM338K adjustable voltage regulators. They are inexpensive and will easily handle up to 5 amps and more at 1.2 to 32 VDC.
The 1.2 V caused my locomotives to start moving so I added two 5 ohm resistors to the output on each side to bring the voltage down to zero. They only get slightly warm when in use.
Some scrounging at the local surplus stores located the necessary parts, including the capacitors and 5 amp transformers. I wisely bought two extra transformers and I’m glad I did, since both stores are sadly now out of business.
I’ve been very pleased with my Dual 5 amp Power Pack since it’s been running. It hasn’t needed any repair since I built it. Operation is very smooth due to the very clean DC that it provides.
I would encourage anyone to try building one. Just be careful when handling the capacitors since the values are rather large. They are needed to smooth the DC output of the bridges and they work very well.
