Early LGB battery-operated train sets and accessories
SevenOfDiamonds
Hi Guys
As "light relief" from the serious (!!!) matter of garden railways, a little while ago I managed to aquire the chassis and diesel cab (engine bonnet missing) of an early LGB battery-operated loco (1981 cataloge suggests product number 209 (though it has "START" and "20601" on the underside) . . .
1738247030418.png . . .
You just put two D cells into the battery holder, and push the lever protruding from the right hand side air tank forwards or backwards for the loco to go in that direction. The chassis and wheels are red, the cab is green. I've added an orange engine bonnet that I had spare, so it's now something of a "harlequin" colouring, fitting in very well with my idea of "light relief"!
I have now managed to acquire a pair of the Change Over Units . . .
. . . (product 130, but also included in Set 300, which featured a steam loco with the same basic chassis), that can be set in any of four positions, to . . .
  • let the loco pass (in either direction)
  • stop the loco and make it go the other way (seemingly, whichever way the loco approaches)
  • stop the loco (whichever direction it approaches from)
  • stop the loco (if it is going in a particular direction)
Unfortunately, I do not have any LGB all-plastic track to fit these Change Over Units to, and the gap between sleepers on the standard brass-railed LGB track is not wide enough. When I get "a round tuit" I'll probably butcher some standard LGB track but the alternative is to try to source some LGB all-plastic track (any thoughts?).
I suppose my question here is whether anyone else has already gone down this road . . . and whether the "amusement factor" lasts long enough to make the effort worthwhile.
Cheers
PS The 1981 catalogue describes these items as being suitable for those "between 3 and 12" but I'm not sure if that's shoe size (tick), hat size (tick), or IQ level (you decide).
I had a battery Klein Dicke for a while, but I since sold it on. It came with 2 bright yellow feldbahn wagons which I painted brown, also now sold on....
If you have brass track, myself I would be tempted to just use the LGB powered tender (non sound version) and push the diesel loco. The coal or wood plastic can be removed.
