I agree Paul it is a magnificent beast, I have been privileged to inspect it at close quarters.minimans said:why not just buy the live steam version? or isn't there one? but yes it does look magnificent.
oberinntalbahn said:A feature that I did not cover was Roger Marsh's simple method of dropping the 'spent' fire.
Undoubtedly not new but novel nevertheless, you will note in the picture that the aluminium plate is drawn away from it's slot as part of the box base and having then placed a dish underneath, the pin holding the grate is removed allowing the fire bars holder to swing down and drop the ashes down.
The ashes are good for the garden so expect added growth as a bonus!
Thanks Charles, I never realized there was that much in common but I guess if you already produce those parts for one project there would be no point in reproducing them in a different form just because it has a Lecky motor!Charles M said:Minimans (Paul ),
I have had the pleasure of working on 2 of Aster's electric models in the past. A 3 truck Shay and the C&S Mogul. At least 90 % of the steam model was in the electric models. Both had full working valve gear and the cylinders were complete. I assumed that they didn't fit pistons to the cylinders or valves in the chests as these couldn't be seen. Both models had " boilers" with blanked off plugs fitted into them . The Mogul had a backhead with added details fitted over the steam backhead. I didn't get far enough into the Shay to see what else was under the wrapper jacket. The sound went into the trailing tender unit .
I was fitting Phoenix Sound to both models for the new owner. .
Charles M
