Started building some fences.
My biggest problem is getting the height and proportions/scale correct.
Started with some picket fencing.
I think station fencing is a lot a taller I based this on the height of my own fence.
I think it looks Ok.
Looking at some L&B photos, there is a lot of fencing made from steel poles/pipes.
had a go and making this. I think the posts are a bit thick but its smallest square section I could find at wickes. I could use smaller stuff from model shops but its quite pricey.
Im not sure whether to make it taller or shorter? Also whetehr to make it look like concrete or wood post. The rails will be painted green. (need to find out what green is SR green. (or perhaps GWR cream)
Seems most fencing posts are 3"x3" which in 16mm is about 4mm, though.
Gonna make some wire and post fencing, when I work out how to attach the wire and also some 4 or 5 rail wooden fencing. Dont want to have to use 5mm square wood unless I can finda cheap source.
