AndrewK
I've just acquired some miniature MR63ZZ 3mm inner diameter bearings recommended for the 3mm diameter steel rod axles belonging to a wagon I've just 3d printed.
My problem is how do you insert the axles into the bearings? I've just tried the sledgehammer/walnut approach (well it was a hammer!) and rendered the first bearing almost useless owing to the very tight fit.
Is there an easier way to do this? Any suggestions greatly appreciated.
