Fitting Massoth Auto Couplers.
Nodrog1826
Professional Idiot
Having been asked if I could post something about how I have fitted Massoth Couplers to locos, here goes.
It's fairly straightforward, just follow the instructions that come with the chips, and set them up to your preferred function number, I use 16.
But experience has thrown up some observations.
LGB and Massoth chips sometimes have problems working two couplers at once, so you may need an adapter, or a function chip to do the job.
Ensuring the cable is not trapped, has resulted in some interesting routing of it.
Modifications to the loco may be needed, even on the easy fit options, had to do some cutting and drilling on the locos, and even some filing on the coupler motor housing to get it to fit.
Anyhow pictures say a thousand words.
Stainz.
Rear is straightforward just a hole and a notch to run the wire, front you can either cut into the gearbox cover or modify the front coupling and plow, to move the coupler forward. (Have to say it's something I have copied from something I found on the web.)
https://translate.google.com/transl...u=http://stummiforum.de/viewtopic.php?t=65319
Ge 4/4
Sort of the same, bogie modified to suit, hole for wire, and I fitted a function chip for the couplers, after it struggled to operate two via the existing set up, my preference.
D4
Basically the same as the Ge 4/4, but more of a tear down to get the cable routed. It was fiddly and my ten thumbs don't help.
This is the one where I had to file the coupling as it was too long to fit where the original was. The tops of the motor housing screw fixing shafts had to be trimmed down as well.
Screw housing I had to trim to fit.
Thanks, that's helped no end it was how you got the couplers to work but i see you used a function chip,
I have posted this in another thread possibly two before but here goes again. Terry Soham on his Festiniog Funkey had auto uncouplers at both ends, no hook only loops. The loops swiveled upwards controlled by an Electro Magnet something like used in a H and M Point Motor. In fact one of these halfs each end these would probably do do the job nicely. The Coupling loop has some Steel on it and as the Magnet is powered up so both the Couplings lift to allow uncoupling. Though looking at th epic in close up looks more like an opposing reaction. Though perhaps the Plasticard that has dropped is to stop the hook dropping too far. Hmm. I would imagine this to be eminently possible via a Massoth Chip.
Sorry if pics not the best, but best I could manage on my own.
