Fn3 Berlyn Goose #6
mrosche
Hi,
New guy to the Forum here...quick question:
I have inherited a somewhat battered Fn3 Berlyn Goose #6 and one of the drive chains on the rear truck is beyond repair...could someone possibly point in in the right direction as to where I can secure a replacement chain?
Any and all suggestions are welcome!!!
Regards,
Mark Rosche
Nürnberg, Germany
Hi,
Regards,
Mark Rosche
Nürnberg, Germany
Not sure if it will work as you would need to put new sprockets on the axles but Delrin Chain may work for you. This is a link to a UK Supplier but may be available in Germany as that is where your icon on the left says you live.
Note that there are different size sprockets if you look at the two sub menus.
Thanks for the tip, I will check it out. I have also found some mini sprocket chain from MicroMark in the US and have ordered a foot of it...measurements look similar to the broken one.
Cheers,
Mark
Mark, can't help you with your issue, however, welcome to the forum :)
Welcome to the forum Mark. You've found the place for good advice, just beware of the not so good jokes
I recently bought some brass chain which came with a large and small sprocket from China. It has the same pitch as the stuff from MicroMark.
