JimmyB
I posted about problems with my gas charging adaptor:
I have now investigated both of these adaptors, and what I have found is that the top and bottom fittings are just pressed in to the tube (interference fit) and with the split the pressed in part come out quite easily, hopefully the photos will explain thing better:
The split on this one is the "bottom" , on the can end of the adaptor
This one is split at the "top" the part that goes to the loco filler.
My plan is to clean and solder the parts back into the tube, which should repair and solve the issues. I will report on my progress.
