ROSS said:Doug said:The Accucraft ones are tested to 300psi i think. Look on the 16mm Assoc website for gas tank testers, they might be able to help you with advice
:-300 PSI!! That's a bit of overkill isn't it?
dunnyrail said:ROSS said:Doug said:The Accucraft ones are tested to 300psi i think. Look on the 16mm Assoc website for gas tank testers, they might be able to help you with advice
Not sure what recommended test pressure is for gas tanks, but I do know that it is a lot more than for a boiler. So 300 psi may not be far off the mark for safety. Both propane and butane gas get to quite high pressures when hot and we are in a warm environment with these.
The Sugestion of using an Engineering Society or 16mm meeting is a good one. I used to do boiler testing at the Beds Group and at that time we were not set up for Gas Tank testing. However all that is needed is a small turned and threaded set up for a specific item to be tested and your local 16 mm group may be happy to oblige. We used to make a very modest charge for the testing service that covered the cost of the Engineering Bodies Certificate that we used to issue. Can't remember the cost but it was less than £5.00, a small price to pay for peace of mind.
2bar/litre. These consumer items as supplied in 16mm/G/G1 sizes legally conform to the SEP (Safe Engineering Practice) component of the EEC Pressure Vessel Regulation, come with a manufacturers cert and do not need to be tested unless they suffer damage. There is a huge amount of fuss and bullshine about boiler testing ? and for the majority of us it is neither a legal or safety requirement. It is interesting to note that the boiler testing fanatics once noisy in the 16mm Assoc went all quiet when asked about gas tank testing because there were no facilities for doing so. Again these little boilers are hugely over engineered and while I have seen an old brass boiler fail, and 'fail' is exactly what it did ? they will not 'blow up'. it developed a pinhole inside the smokebox at the hottest and narrowest part between firetube and wrapper. This was only noticed when performance fell off a bit. I have seen a boiler tested to destruction and after well over 400psi this roundhouse boiler failed. By this time it actually looked like an orange in terms of shape ? so if your boiler begins to look like an orange ? then turn the gas offROSS said:see my post #9
I understand that if the boiler holds less than 2L then no test is required????
TAG???
bobg said:but try getting that past a club tester.
stockers said:bobg said:but try getting that past a club tester.
Who is probably following the requirements of the clubs insurer rather than the letter of the law.
In these days of 'Safety Assessments', it is conceivable that one might be considered to be negligent if one tests most boilers but ignores others because the're small. If an injury occured, then it wasn't too small was it.
