stockers
Running Heidi at the weekend she seemed a bit rough. This has always been a very smooth runner with good electrical continuity.
Whipped off the base plate and had a good look. One problem was slightly jerky running - as if something was binding. Yes - you guessed - the quartering was out one tooth. It took a bit of careful examination to determine this - at first it looked all OK until I rotated the cranks to bottom dead centre and forward dead centre. Then I could see that the rear axle was one tooth behind the front.
She also stopped a couple of times on frogs. I got out the test meter and found that continuity between the skates and the wheels was patchy - on investigation I found the skate spring on one side was binding and on the other it was partly compressed, permanently. Also one middle wheel was hit and miss as to whether or not it picked up. New massoth skates - didnt fit. Well they did but were too tight in the slide and binded. So I refitted the original ones with the massoth new springs. A new pickup plunger solved the wheel pick up.
On to the track tonight just after dusk and she ran brilliantly, smooth and slow, over pointwork and falling petals from the magnolia tree - didn't miss a beat - beautiful.
Sorry - no pictures of the works - too busy.
