stevedenver
as of late,
it seems everytime i run either my aster frank s or my SRRL 24-
both over 15, the aster with not that much time or use, and the SRRL seems rather unworn to my eye as well
things fall off, screws unwind, hoses burst, pumps jam and have to be removed and the ball plug freed, jets cleaned, truck frames loosen, ad nauseum etc -not all at once, but it seems theres always something
last time i lost and replaced a screw-which happened while running-just popped out of the main driver dislodging the entire drive assembly and eccentric, i inadvertantly misaligned it, having used lock tite , and thinking the slight 'resistance' i felt was the lock tite setting up and ended up ruining the portion of the axel which takes the screw,
and a complete drill out and re tap with a sleeve insert-alas i digress
its a right PITA
i am really careful, because they are relatively pricey and a pain for me to repair because i only know mechanical and electrical stuff
they are handled carefully, cleaned and put away in padded cases, and are regularly tidied re steam oil and grit
so
ive gone to tightening every little screw and nut each time before i run, careful lube, really a thorough once over
is this common or is this unusual
its a right PITA
so
