The Hobb-E-Lube set has dry graphite which sort of puffs out in roughly the right place - very good for plastic wheels in plastic axleboxesMorning, lovely morning. I’ve read quite a few dos and donts about grease and oil. i want to lubricate the plastic wheels on my carriages and wagons, what do people use?
Yep - that's the Hobb-E-Lube stuffEven better graphite with powdered moly! (this is my preferred lube for metal axles in plastic sideframes)
Second dry graphite I have a puffer as used by locksmiths.Uhh... smoke oil is sometimes a bit of solvent... better to use regular oil... Smoke fluid will usually evaporate after a wheel.
Yes, I know that some smoke fluids may not evaporate.... but why not just use purpose formulated oil?
For me, dry graphite for metal axles in plastic journals attracts less grit...
Looks good, not sure I would want to breath through the snorkel thoughWell, I have another kind of graphite I use when I need it to wick in:
graphite powder in a carrier that completely evaporates. Great for things that cannot be disassembled (like a lock, or shaft, or bearing0
